One more question, are network prime time shows in English?
yeah no duh. I can see them on C-Band and they are OK on there at best. Issue is they are cramming 4 SD, 1 HD, 1 part time SD and 1 blank stream and arent using a full transponder to do it. Maybe 1/2 of one.It should be noted that SD video quality is bad but watchable
legally they CANT right now
They can provide "distants" as in fill in markets where there isnt the full slate of nets in a market. Distants for RV folks and the such they do not have (last I checked) the ability to do
Iceberg said:They can provide "distants" as in fill in markets where there isnt the full slate of nets in a market. Distants for RV folks and the such they do not have (last I checked) the ability to do
Since ABC is the only affiliate with a PR address, the other come from other markets. When Dish gets the Distant Networks available, can Puerto Rico qualified to get the Distants?
Guess it's time to look up a PR address
holy_devil said:Not a bad idea, but i think you would prefer to look for one in Rochester, NY since they have HD networks on 61.5. Well that's if you have a Dish aim at 61.5.
Yes man we have said this for a couple of times remember guys the Strorefront Channels are LOW POWER WSJP, WSJX, WPRU channles if they were FULL POWER and were avaliable to the entire Island then no we can not recieve Distants
so are you saying as I recieve no locals in USVI i should have access to distant networks from Dish or are you referring to AAD?
You are right, I totally forgot about that, I used to have SD distants thru ADD before they offered HD, but the quality was as bad as our locals. I never tried the Hd service.
Here my wishlist:
1. Hd premiums back. (no matter in which sat as long they are on PR footprint)
2. HD distants
3. The missing HD channels from the PR pak.
Here my wishlist:
2. HD distants
Nel I'm not sure but last year you said that the locals will be in Hd. Wapa is in HD. Someone mention (i'm not sure it was you) that National Geographic LA and Discovery LA will be in HD also. It's that still a possibility. I noticed in The List that Spotbeam B23 has 3 tps 1,3 and 5. tp 5 only have one channel Wapa HD, that means there room for more HD right? Also SB22 has only one channel WGN HD what's the capacity for SB22, do you know?
