Orlando Getting Fearnet HD, HBO HD On Demand and Cinemax HD On Demand
HDOrlando
83
Longwood, Florida
It was in the Orlando Sentinel local and business this morning.
April 20
HBO HD On Demand: Channel 1400
Cinemax HD On Demand: Channel 1420
May 9
FearNet HD: Channel 1393 ($7 Movie Pass)
Movie Pass HD On Demand: Channel 1394
Apparently they are having trouble loading them into the guide.
Hopefully, they can get them up soon.
Some might be able to get them though.
Here's how you can do a trick on your remote.
1) Go to a non Start Over/look Back channel. I use channel 14 and no I never actually watch it.
2) Press Down the OK/Select button and hold it down until you see a dot flashing above your box timer.
3) Then immediately hit the right arrow next to the button and punch in the channel number (!400 HBO HD OD and 1420 Cinemax HD OD)
I have looked at the HBO HD OD and it's almost identical to the SD version.
The only difference is anything uploaded before they put up the test channel is not there but anything new added to the SD version since then is on the HD version.
They also have the SD stuff on the HD channel but there is not a lot of SD stuff and it's listed as upconverted to HD.
Hopefully, they will have it up soon.
Good to finally have it up.
Cinemax HD OD (Don't have Cinemax) should be up Thursday.
Let's hope FearNet HD and Movie Pass HD OD launch on time two weeks from now.
FS Ohio HD is only other outstanding channel and it's apparently still unavailable.
iPhone dvr remote never works?
So i have to have a set top box for FIOS?
