I cannot watch any of the online dish programs when I log into dishonline. It keeps telling me to install adobe flash player, when I click the link to adobe it tells me I already have adobe flash player installed. Now what?
Dish online requires 2 to 3 flash components to be working.I cannot watch any of the online dish programs when I log into dishonline. It keeps telling me to install adobe flash player, when I click the link to adobe it tells me I already have adobe flash player installed. Now what?
I couldn't get Dishonline to work just to stream from the site, not my receiver this past weekend, couldn't really even log-in (Chrome, Firefox, or IE). I could get up to the log-in screen, but then when I tried to log-in, it just froze and didn't do anything. I started having a differing opinion on the dishonline.com pop-ups in Platinum at about that point.
I wanted to watch something off of Epix, so I just went over to Epix's site, logged in and it worked there, almost flawlessly over the period of one and a quarter hours.
Ok.. so the problem you are having isn't dish's fault (technically) ... start by using the adobe uninstaller and instructions on this page:
Uninstall Flash Player | Windows
please don't second guess them.. close *everything* before trying to run the uninstaller ... (bookmark the page so you can get back to it after you've restarted your pc).
You're looking to make sure that you get the message that tells you flash was not found when you go to their flash check page. *then* install flash from Adobe's site like it says.. reboot ... check again that adobe sees the right version ... once that's done ... check dish remote access or dish online again and see if those prompts are gone.
And remember if you get a new one, make sure you check that its still asking for adobe flash, not one of the other plugins.
If that still doesn't work, and you continue to be prompted to install flash.. then you've got a flash problem that isn't necessarily related to Dish ... dish simply requests to know the version is X or greater... and with flash there have been known problems where 32/64 bit installers behave differently so that could also be a problem. (32/64 presuming you're on a 64 bit windows 7 install)
You could also uninstall or try the uninstaller in the IE9 32 mode (look for an IE icon in your start menu/all programs and submenus that identifies "32 bit mode")
I followed this twice, each time it failed and I keep getting the same results. Each time I click a show it tells me to click to install, do that it takes me to adobe page, when I click to install (after I have installed from the website) it says it already installed. Stuck in a loop here.......
Are there version issues? And assuming that after you uninstalled Flash ... it showed flash as not installed..yep...had it since day one...suport is aware just dont do anything or even talk about it....sorry your in same boat as me.
Dishonline is extremely, extremely slow tonight. Tried connecting and it is taking forever to respond to mouse clicks. HBOGo, no problem.
Sorry, I thought this update had been posted here.
"This past week DISHOnline.com has experienced extremely high latency starting daily around 4:45MDT – this is a known issue and we are working with Sling on a fix. At this moment there is no estimated resolution time"
Don't you need a hd reciver to acess epix In free preview??? I all ready have epix via dish platnum
