Anyone hear anything good or bad about a SatHawk 6910 Signal Meter? Just seen it over on Sadoun's web site. They are selling it for $199. Seen it a little lower on ebay but not much. This would be useful rather than dragging out the receiver and TV.
Looks like I will using the receiver and TV method.It is an OEM model of a SatLink meter. Sensitive tuner, easy to use, but poor battery life and the editing program fails. Several other meters available that are probably better candidates. If you are willing to spend a few hundred dollars and want a meter that will be around for a few years, I would consider a meter that can identify DVBS as well as S2.
We were looking at distributing the SatLink WS-6912 S2 meter, but the manufacturer wasn't able to address several major issues including battery life. Company has been in the meter business for several years, but not very strong in development.
Looks like I will using the receiver and TV method.![]()
I bought one of those no name meters from China for just over a $100. It saves dragging out a receiver and TV. Battery life has not been an issue for me.
Or you could just spend 170 dollars and get a FS1 meter.
The FS1 is made for MPEG2 signals but has the ability to detect other signals. See the chart below.
From the FS1 web page.
- MPEG2 SD Signal / Quality / Lock
- MPEG2 HD Signal / Quality / Lock
- MPEG4 SD Signal / Quality
- MPEG4 HD Signal / Quality
- Digicipher Signal / Quality
- Digicipher 8psk Signal / Quality
And that meter tells you the satellite you are on? Hmmm....
Interesting meter, and TV. MS, where did you dig that one up?I bought one of those no name meters from China for just over a $100. It saves dragging out a receiver and TV. Battery life has not been an issue for me.
We talked about those meters hereInteresting meter, and TV. MS, where did you dig that one up?
RT.
I received mine very fast and have had time to "play" with it. Without question, it is better than dragging all that "stuff" out to the dish site. After a few charges and discharges(use)the battery meter holds for at least two hours until it shows it is low. Have not kept it running to see how much longer it my go until dead batery, so it could last longer. The video display is a nice feature. Gives you an idea of what you have found. Has settings to control your switches if you just want to test things from the house. In my case, I use that feature to go to the box that has my Ecoda switch. I can remove the line from the receiver, attach a coax there and to the unit. That way I do not have to remove the water proof gummy stuff at the dishes. The meter may not pick all that is out there, but you can get enough to know you are on the sat you were looking for. The manual does have pictures you can actually see, but does not give you as much information as would be helpful when learning to use. The advertising states security cameras. Well, it sure does not work with real CCTV cameras. Maybe A/V from a camcorder or something simular. Some flaws are the fact you really do not know what you received because unlike well know brand names there are not real information labels on the unit. An example would be my Sony HD recorder. Label has all information as to model, S/N, date of manufacture, etc. Can not find anything like that on this unit. I will have to guess I have the Sathawk 6910? Software updates looks like a joke. You can find nothing anywhere to update it with. Another flaw is on the display. When you have a picture(channel)running and press the info button, a gray square smaller than the display comes on and the black info is displayed on that. So you can see it. Problem is they do not line up. You cannot read the first three lines unless the background is a very light color.Anyone hear anything good or bad about a SatHawk 6910 Signal Meter? Just seen it over on Sadoun's web site. They are selling it for $199. Seen it a little lower on ebay but not much. This would be useful rather than dragging out the receiver and TV.
...Maybe when the 9199 version comes out it will go out to the dish, hook it's self up, turn on, find a sat, and yell back to the house what it found! Now that would be a meter!
I like stuff with lots of buttons. Gives me more options. ...
Where I live the city is laid out exactly north/south east/west so aiming a dish is almost childs play. I use the meter for fine tuning. I don't need to know what sat I'm aimed at, I allready know.
