I just did a scan of that TP on 118.8W, and to my disbelief I'm actually picking up one scrambled channel there. It's marked "Ch-998". I'm using a linear LNB... the Invacom SNH-031, which is why I was so shocked to get anything. Pixl, I may look into that LNB you mention. I'm also using the Openbox S10. Thanks for the info.
Andrew,
It's not the circular lnb that is a secret weapon. Although it is the best way to get circular, you can, as you found out get some signal on linear as there is some bleed over either way.
The channels are also hidden and require manual pid input. For the OpenBox you have to do this on a channel editor. Here is the info posted by Perseus elsewhere on the net.
Anik F3, 118 degrees
Channel          Freq/Trans      Pol.                APID                          VPID
KNXV           12185            L                    4131, ENG AC3          4130
KPNX           12185            L                    4643, ENG AC3          4642
KSAZ            12185            L                    4899, ENG AC3          4898
KNXV = 720p, KPNX = 1080i, KSAZ = 720p
Symbol rate for all 3 = 20000 3/4
In addition to the above info, I found on my OpenBox I had to change the video from Mpeg2 to H264, again using the editor.
So if you are seeing $998, it's worth trying to edit in this stuff.
