i have the radio shack usb-a to serial cable adapter with a db-9 connector.  i can connect any pins with female to female connectors.  i can't find if it is a pl2303 though.  fortunately my updates are working properly though.  charlie
			let me run this by you while it's on my mind. I have a four cable TTL dongle coming but I don't recall if it's 3.3V or 5V or if I even knew there was a difference when I ordered it a week ago. When it comes, can I test it by plugging it in the USB port of my PC and measuring the voltage on the voltage pin and if it's 5VDC, it's fine?Please note that the 3.3v TTL cable does not work. It MUST be the 5v / 4 pin version as described in the guide.
I found this cable, which appears to be what is needed...http://www.ebay.com/itm/USB-to-seri...rial_PS_2_Cables_Adapters&hash=item41619267ba
Has drivers available too
I contacted that seller and asked about the VCC spec. He didn't know. However I don't see anything about that item that confirms it is wrong either. So we all have high hopesBefore I read the last post, I ordered the one that ke4est mentioned at post #8, I hope that this one is the right type needed, there was no mentioned of any voltage values in the ad.
I know I am worried now...I followed the original link that Brian had post, but it said this one was sold. Sooo I clicked the thing that said view similar items. I did note when eBay did that it took me to 3wire and 4 wire ones. I made sure to get a 4-wire set-up, but didn't even look to see that it was 5-volt:doh:. They apparently ship faster than he says, according to them it said I will get by September 27th. However, according to tracking I should have it by Friday, so I will check and report as soon as I get it.
