the no rs232 is a handicap.
I believe the openbox series with the same processor-the firmware is encrypted.
I've heard the same thing, but I wish someone could get too it, and change a few things. I like the X3, but it needs a few mods.
Im charging the battery pack in my camera so I can get some good pics of the board inside of it i also have a dasm of part of the code that says the chip is just about the same as a 3602Thanks for all the updates Bugs. Can you get some better pics of the guts that aren't blurry?
it looks like it has a place on the board for a db9 connector under the riser board for the tuner but it would have to be rigged to fit it on the case with probably a ribbon cable so you could place it in a remote location on the case
that would be well worth doing,then you can play with the euro firmware without ripping hair out.
remote tables would have to be edited to match your remote tho
I run an older version of the TDVxxxx-x-x-x-x firmware on my openbox s10,so that looked familiar.
on the s10 I make sure the firmware boots,then the tuner works,then worry about getting the remote buttons working 100%
it shouldn't,different pro cessor
I used disasmips and now have a full dasm of the code its mips32 based
Are you in Louisville KY? I would love to see this STB in person.
