I am replacing an HR22 reciever in my RV with a HR24. The HR24-500 was activated with Direct TV in my house, which has a Slim3 Dish. The RV has a n 18X20 - 3LNB Dish. The HR22 still works, and I can get receptioin in the RV using the 18X20 Dish,
When I plug the HR24 in, and go through Satellite Set-Up and changed to multi-switch, 18X20 - 3LNB; I cannot get a sattelite connection.
I have tried all of the 3LNB options for Dish in Setup, but nothing works.
When I check the signal strenghty with the HR24 plugged in, I get good readings for Satellite Transponders (32 total at 101 degrees), that generally read 85 - 100. When I check the Signal Meter however, it reports that neither Tuner 1 or 2 is Aquired.
Will the 18x20 3LNB Dish work with this reciever or do I need to get a Slimline? I understand I will not get HD Channels with this dish, which is OK for RV, if I can get it to work. Does anyone know what I need to do during the setup to get it to work, if at all possible?
to Satelliteguys!
