MSRP: $5,000 USD
Living with the X55 for a few weeks, I come off overall highly impressed with the unit. If you value contrast above everything else, and the ISF finds it to be the single mode important element of an image, then the JVC is untouchable. It also has a default mode that is very, very accurate and can be made almost perfect with calibration. The lens memory and setup options make it a very flexible projector to install, and from a usability standpoint it is top-notch. The real proof is how often I just got lost watching the thing and marveling at the images that it can produce on my screen.
Despite all of this good, it also has a couple of issues that make it a projector I can't universally recommend. After calibration on my 96", 1.3 gain screen, I got just 18 fL of light on the screen. This is slightly over the correct amount, but projector bulbs age, and with only 18 fL at the start it gives me nowhere to go from there. It also makes it so that if I use Lens Memory to fill the 2.40 screen, I'm dropping well below that 18 fL level. Couple this with the fact that the high lamp mode is very loud to use, and I have trouble recommending it with very large screen unless you are running a high-power (2.0+ gain) material.
Link
