A whole lot quicker, then trying to drill through the pole.
5 minutes ...
Btw, do you carry a Mig Welder on your work truck ?
Besides, the poles these guys are putting in are not all that heavy.
5 minutes ... Btw, do you carry a Mig Welder on your work truck ? Besides, the poles these guys are putting in are not all that heavy.
I went a little overboard with the water so it is a soupy mixI normally give it about 20-30 minutes then pop the dish on. Quikcrete is pretty amazing stuff if you didn't flood it with water it sits up quickly and nice! Depending on how "north" you are you're prolly getting the rain I'm seeing on and off today
I do not get where you think that everyone on this site is a contractor for Direct. As a homeowner, yes I do have a Arc Welder in my garage. It would take me all of two minutes tops to weld four four inch bolts on a piece of Fence stock, to allow the pole to have something extra to hold it in the concrete, when I place it in the hole in the ground, before dumping in a bag of Quikrete 1004 mix.5 minutes ... Btw, do you carry a Mig Welder on your work truck ? Besides, the poles these guys are putting in are not all that heavy.
If it moves at all tomorrow, pull it back out, get that stuff out of there if you can, or place the new hole over some, by using a Post Hole Digger to get at least a 36"-42" hole in the ground. Then just dump in a bag or bag and half of Quikrete #1004. Follow the directions to the T, regarding how much water to pour into the dry mix, and it will be solid in a hour, that you can then place the dish on the mast, and be done in two hours tops.I went a little overboard with the water so it is a soupy mixIll give it 24 hrs and see how sturdy it feels. We get some pretty strong winds here.
Excellent!
