After having another switch mounted on my roof go bad, my installer replaced my 2 antenna setup with a new single triple LNB antenna (not sure which model as it just says Dish HD on it, no model number that I could find.) The new antenna just has 2 cables and these currently are used for each of my two existing receivers. I'd like to add 2 more receivers, but not sure if/how I do that. I assume there would be a switch that I run the 2 cables coming from the antenna to and split to 4 cables that run to each receiver (each receiver has a triplexer as they are all dual tuner receivers.)
Was thinking something like the DP34 would work? Can I actually run 8 tuners off the one antenna (sure hope so!)
Mike
Mike
