You're using logic to determine the price... Doesn't mean that Dish will !
Sent from my SCH-I535 using Tapatalk
All we know for sure is that the Super Joey will be a savings from having a second Hopper. So we know it will be less than $12 a month.
I use the cost of a super Joey from the perspective of whether to get a 211 (add an external hd) to support a 2nd TV or upgrade to a hopper and super Joey.
A 722 w/ 211 is 2 TVs and 3 tuners. A hopper super Joey is 2 TVs and 5 tuners. It is also ~$5 more a month, maybe more. But I still can only watch 2 TVs. Of course that is my logic, as noted.
I doubt there will be any need for a duo node on upgrades, no need for the expense. A small and relatively cheap diplexor type device with "to node," "to dish," and "to joey" ports. Connect as labeled.Watching the video ... if you have a 1 Hopper 1 Joey setup ... to upgrade to a SJ ... the easiest install would be to run the 3rd line from the dish to your node ... swap the solo out with a duo node ... swap the Joey out with the SJ ... and your done.
My question is with regards to the HWS. When slinging you use one tuner. If all of the HWS tuners are being used ... can the HWS route you to an unused SJ tuner?
For new installs, they might standardize one a duo node, but my guess is the band stacking electronics, weight & size of a duo would add up to be more expensive than the diplexor.
You are looking at it from a very basic view. The Hopper system adds soooo much more. Not only are you getting more tuners but you have access to all your recording on all your TVs. You only have to set one timer instead of a timer on each receiver. You have bonus features like Sling and the Transfer app. Can't forget about PTAT and AutoHop. Those are just a few of the features the Hopper has and Dish just keeps adding more.
lolz easiest install huh, well its not always that easy to install when you have 2 perfectly good lines say under 50 feet of dirt or perhaps on a tall roof that took a ton of time to wire up already just say a year or so ago. Dish just did NOT think this thru if they keep this requirement. Sure I like new hardware as much as the next guy but they have to think of the back end and help the customers out to avoid over cabling the home. Can't say its easy when you try to explain to someone that the current wiring in a house isn't enough when it very well could be.
You were fortunate. Neither Directv nor Dish run more lines than necessary for a particular job. To do so would be considered waste.The house I just purchased has 4 lines running from the dish to a central coax box. I can't take the credit ... but someone was thinking aheadHence for me ... it is just a matter of throwing a connector on the 3rd line to the dish.
Great question we will find out Tuesday.
The chap who came out to upgrade my dual-arc Dish insisted on replacing cables. I have 3 dual-tuner receivers. Guess which cable they had in their truck? Big ugly black dual with ground wire, and that's it! He intended to do the job using 4 cables (and two ground wires) until I handed him 3 separate nice grey cables with factory molded 4-connectors on the end. He promptly cut off those sealed factory ends and crimped on new ones, making them a tad too short for the job.
As an installer, you are free to re-use existing cables -- at your risk -- are you not ?
As a retailer, yes, we can do about whatever we want but risk a call back.
