Just checked the HR24 and everything is working fine, then again they are not running the same software either.
No haven't changed anything ever!!Have you changed to a few different channels yet ?
Like I said, I only had trouble with the Genie, not the 24.
Didn't mean to change settings or set up ... I meant change the channels to different programs and see if your Audio stays ....No haven't changed anything ever!!![]()
Since this last CE update Audio was good when changing channels but go back on Dvr Audio still is going out but not as bad as 1st was!!I am just going to stay n this they will come out to improve it with next couple CE's!!Didn't mean to change settings or set up ... I meant change the channels to different programs and see if your Audio stays ....
At least NOW, if you do lose it, you can reboot and get it back with the NR, unlike when this happens in the CE time frame.
The purpose of the CE's IS BETA TESTING.
Hows that again ?I've gotten audio back after a cut-out by one skip back. Annoying, but workable.
Ill have to try that next time.When I have no audio (usually out of a pause), I can hit skip/slip back once, and it comes back
