- Apr 24, 2008
- 3,219
- 448
A3 ROM31 is available from the Amiko Software Downloader App.
Since this is the first ROM available for update in North America please carefully read the update instructions here: http://www.amiko-a3.us/guides/AMIKO%20RO...CTIONS.pdf
The system will remind you about making a backup. If you have not backed up userdata and apps you need to do this. Instructions are here: http://www.amiko-a3.us/guides/HOW%20AND%...R%20A3.pdf
A normal ROM update will not wipe userdata and Apps but better safe than sorry. You need a backup just in case something ever goes wrong or you wipe userdata.
The main improvement for us in ROM31 is with the Software and Satellite Downloaders. You no longer need to go to "downloads" and delete the temporary files. A3 will do this on the next boot. Note: it does not do this right after installing a ROM, it is the next time it is booted/rebooted.
Since Conax basically is not used in NA/NZ/AU it has been eliminated. If you want it you can install from A3 Appstore as a userapp that you can delete.
Spark2 Weather App has also been eliminated from the ROM. Like Conax you can install from A3 Appstore if you want. The Weather Channel and Accuweather Apps are also in A3 Appstore and on Google Play.
Other improvements is the addition of animated boot logo, general bugfixes and some things for DLNA.
This ROM does not address the Diseqc 1.2 position numbers being -1. That will be addressed in the next ROM. Likely we will release a dev version of this early.
