Got a bit of fine tuning to do. Am I correct in saying that the lnb has to point at the deepest part of an offset dish?
It is also very important from where you point your LNB! If LNB is located in antenna's focus than it should be pointed such a way that it's direction divides angle "lowest antenna's point" -"Focus"- "Upper antenna's point" exactly on half. What antenna are you speaking about?Am I correct in saying that the lnb has to point at the deepest part of an offset dish?
You mean, it is prime-focus? Than, of course, LNB should be pointed to the very middle of the dish whish is also deepest point of it. You could show some pictures of your dish and it's feedarms and LNB holder.not the oval type
The original lnb is shot.....I have a different lnb......The original lnb holder and original lnb are an odd size....my other lnb does not fit the original lnb holder properly. I am going to order another lnb like the original and then it will fit the original holder.Than I do not understand something: why should you buy new LNB as it will be pointed at exactly same point on antenna surface as old one?! I think you should do something with LNB-holder or feedarms, not LNB.
I have the same dish. I used a lnb holder that came with a multi lnb kit. Easy to find this type on ebayView attachment 105275View attachment 105276
Exactly! It has the 50mm with an adapter for 23mm but my lnb is 40mm. I will try the pvc pipe. That sounds like a good fix.One clamp size was for the "pop can" LNBF. I think the clamp size was 50mm. Another clamp size was for the 23mm mounts. They also manufactured a shim kit for the 50mm to clamp 40 and 23mm LNBFs, or you could use a split PVC pipe for clamping the smaller 40mm LNBF.
