What are the advantages and disadvantages of a roof mouted motorized dish
jmc98
822
43
32.750N 97.488W Fort worth Tx
I have a 90 cm on a stab hh90 mount on a tripod that no matter how hard I try I can't plumb the mast that is in the tripod so I am considering a roof mount on an old direct tv dish j pole that already in place
Reactions: spongella
primestar31
13,567
14,029
Beta Omicron Delta III
There's no advantages for a motorized roof mounted dish, versus one mounted on a ground pole. There are however MANY disadvantages, here's a few:
1: Mount could leak during rain, and you won't discover it until it causes expensive damage.
2: BIG windstorm could rip it off the roof, then cause even more damage as the dish skitters to who knows where.
3: It can be hard to get the whole thing installed and peaked properly, because the average homeowner doesn't have the proper equipment to do it right once and DONE. So, many trips up a ladder, make tweaks, climb down, check tv, is it ok? Back up the ladder! WHOOPS, I fell off the roof!
FTA4PA
Satellite Guys Family
7,621
5,952
Central Pennsylvania
Lots of disadvantages. Only two pluses that I can see to are roof install:
1. Allows someone who doesn't otherwise have a clear view of the arc to put up a dish.
2. Depending on your neighborhood, it would keep the kids away (think vandals :eek:)
Best to avoid it if possible. :)
spongella
1,625
1,236
Central NJ
High winds on the roof could knock the dish out of alignment, then it's up to the roof you go. It can happen on the ground too, but much safer and convenient. As was said by FTA4PA you might consider putting it on the roof if there major obstacles to the satellite.
Pole mounts have the least moving parts too in comparison with J mounts have extra bolts to deal with that can cause the dish to shift, loosen, etc.
Believe it or not there is an old colonial house in the next town with a 10 foot dish mounted on the roof ! I could not sleep nights if I lived in that house.
Reactions: FTA4PA
Jim S.
When someone asks you if you're a god, you say yes
5,669
1,291
FN11od
Do you know that the J pole is plumb?
Another thing to consider is that if you can get your tripod mount to be level in the east/west axis, you can compensate for it not being level in the north/south axis by adjusting your motor latitude. (That's what I did for my J pole, which is a GeoSatPro J pole that theoretically can be plumbed no matter how unstraight the foot plate is, but I evidently have bent the hell out of something because it just isn't happening.)
Cosmo Blatz
580
462
S.E. WI and Central NV
Get 3 cheap magnetic levels and stick them to the tripod 120 degrees apart. Level the tripod! (Definitely keep it on the ground.)
Tip: Grab the best large 'professional' level the store has. Compare the cheap levels to the 'professional' level and buy the 3 most accurate cheap levels.
fred555
Pub Member
7,976
7,024
77W
I'm thinking of mounting a fixed dish not on the roof but on a gable. I don't like putting holes in the roof. This option will save 75 feet of coax to run it to the nearest clearing in the woods for that sat. If you need to mount one up high consider the gable instead of the roof. This setup may also provide some protection from wind.
jmc98
822
43
this where i would mount the dish on the roof
jmc98
822
43
do you adjust the motor latitude up or down or can you adjust dish elevation up or down ?
Titanium
AI6US
7,650
9,065
Meadow Vista, Northern California
The motor elevation is adjusted to compensate for the pole being out of plumb. Warning: this only applies if the pole is out of plumb EXACTLY in the North/South axis. It will not correct for any East/West leaning.
As in any motorized dish install, a perfectly plumb mast is the key to successfully tracking the arc. Attempting a motorized install on anything but a plumb mast is a sure recipe for frustration and aggravation! :)
You are likely to find that the existing DirecTV j-pole mast on the roof is too short to allow clearance of the dish from contacting the roof when mounted on a motor. Most motor designs lower the dish about 6".
Cham
VE4GLS
2,550
1,122
Boonies
I only have one dish on the roof, and it's there only because it was the only location from where I can see the eastern horizon without a building or tree in the way. (30W) In order to keep the dish solid I attached a 20' heavy walled 4" steel pipe to the side of the roof and have it attaching to a larger pipe that is drilled and tapped with bolts to fine-tune to keep the mast vertical. The bigger pipe sits on a wheel rim bolted to cement blocks.
Tri-pods, at least the ones made to hold up TV antennas, are not really stable enough for larger FTA equipment.
Reactions: beavs2112
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
26,918
7,273
EM75xb
Why can't you make a permanent pole mount on the ground? I assume since you can drill holes in your roof that it is your property and not a rental.
FTA4PA
7,621
5,952
Looks like your house is one story and mount is very near the edge of the roof? If so and the mount is plumb then it might be workable. You would have fairly easy access to the dish by just putting a ladder against the house. Not much worry about clearing snow/ice off dish in Texas. :rolleyes: Not the best way but if you don't have any options for a ground mount then it might be worth a shot. :)
fred555
Pub Member
7,976
7,024
77W
I have also seen where you plant a long pole in the ground, clamp it to the fascia (if you don't have a gutter) and the pole extends above the roof line somewhat. Very stable and no holes in roof.
Mr Tony
2,068
8,362
Mankato, MN
line of site issues is the big one
live in an area that you can't put a pole mount in
one disadvantage (depending on area of location) is it can be a bitch to clean the dish if there is snow on it :)
beavs2112
Addicted to Legal FTA
Jan 28, 2010
814
248
London Ontario Canada
