I have a new 722k receiver one month old that i bough from someone that never used it. I was the first that subscribe it and it fail after it was recording an event and the electricity went off. When it came back it shows an error that said hard disk fail. I let it of for a while and plug it back on. But the problem persist. Then I found an info that talk about hidden menu to check the hard drive. I use that process to go in the hidden menu and select the first method. After it make the test it said. Hard disk fail. And after that my receiver boot and ends with the two recording lights blinking.
I try to format the internal hard drive but its locked. I learn that it can be unlocked by letting the receiver boot for 30 seconds and pull the sata cable from the board and leave the receiver powered until u finish process. Then u can use a sata to usb adapter to make windows recognize the drive and see the internal partition. I formatted the hard drive and put the sata cable back into the receiver then i reboot it but the receiver still show the same problem. The hard drive was partitioned again by the receiver. Still the problem of the two red lights.
I know that the hard drive is good couse i make a full format and test it. Maybe there is something marked internally.
Need the process to make my receiver come back to life. Please help.
