There should be a tv/vcr switch on the remote. Make sure it is set to tv, and try entering 91 again.
			Don't know how but I just got channel 91....what do I do now?There should be a tv/vcr switch on the remote. Make sure it is set to tv, and try entering 91 again.
It reads AV input.....91Don't know how but I just got channel 91....what do I do now?
I have the switch on top of the DirectTV remote set to TV which is all the way to the right ,instead of under the DirectTV logo all the way to the left.It reads AV input.....91
I'm on channel 91 somehow..what do I do next ?Try tuning the tv to channel 91.
I'm on channel 91 now,what do I do next?Try tuning the tv to channel 91.
Don't quit raoul 5788...I moved it all the way back to the left and bingo..DirectTV again..thanks a zillion fellows for all the support.Never would have gotten it without you fellows and this forum.I give up.
NO, in order for you to use the D* service that is using the A/V inputs it needs to STAY on 91.The only thing is when I first turn on the remote it reads AV input 91..shouldn't it read 3 ?..but it's playing great on all channels.
Jimbo,I pushed the switch at the top of the remote like I had done earlier and suggested by Chip and just kept pressing all the buttons and 91 came up.It might have been the Menu button that did the trick..with all the great help from you and the other fellows who replied and this cool forum.Many thanks again.NO, in order for you to use the D* service that is using the A/V inputs it needs to STAY on 91.
So, the question is, if you turn on the TV and it's on channel 3 we'll say, can you get it back on 91 ?Jimbo,I pushed the switch at the top of the remote like I had done earlier and suggested by Chip and just kept pressing all the buttons and 91 came up.It might have been the Menu button that did the trick..with all the great help from you and the other fellows who replied and this cool forum.Many thanks again.
Jimbo,I don't even want to try setting it manually to 3..I thought they all had to be set to 3 or 4?I might never get it back again if I fool around with it.Way too much agravation.So I just leave it as is,correct?Can't afford an updated TV or new one right now.So, the question is, if you turn on the TV and it's on channel 3 we'll say, can you get it back on 91 ?
You really need a newer TV, more updated.
Then I suggest leaving it where it is.Jimbo,I don't even want to try setting it manually to 3..I thought they all had to be set to 3 or 4?I might never get it back again if I fool around with it.Way too much agravation.So I just leave it as is,correct?Can't afford an updated TV or new one right now.
