Excellent (11898-V 22000) Poor (12145-V 22000)
industry_state
9
USA
Hi,
I have 30" dish with an old Samsung LNB.
I have been having signal quality issues with a specific frequency (12145-V 22000) where the signal quality is not stable (jumps randomly between 0%-65%), but the signal strength is good and stable (65%). Other frequencies, such as (11898-V 22000) has stable quality & strength 65%.
I tried to use a new LNB (I got the same issue of jumping signal quality, but with all frequencies). I also tried a new cable (direct line from LNB to receiver), but the issue remained the same. Could it be a faulty receiver (Samsung DSR 3700)?
Any suggestions?
Thank you
For FTA a 30" dish is a bit on the small size. But it is doable. The varying Q is an indication that the dish needs to be better aligned. The solid S 65 just indicates that the LNB is connected. You could point the dish at the ground and still the S will be 65.
What sat are you pointed at?
Some TPs will be stronger than others. Pick the weakest TP and try tweaking the dish for max Q.
I am pointing to Galaxy 19. Could it be an issue with the receiver?
which elevation scale?
What bird did we get?
