That it's I was suspected. The unit itself lands the dish spot on, but in conjunction with a stb (minime, s9, technomate, amiko alien1, v8combo), lands the dish anywhere, not always in the same spot (right or wrong). I did tested 3 actuators (18",24", 36") on the bench not connected to any dish, but to the mentioned stb and a monitor. Asc works perfect by itself without any capacitors or other electronics attached to it, so the so called motor noise is always there if is any.I'm using it with the MicroHD and DVR3500. They control the unit fine and it drives the dish fine.
It does tend to get a little out of place sometimes and I need to shift satellites a few clicks in one way.
Seems it's a common complaint and I guess due to noise on the connection from the actuator to the unit. The old analog unit I used to move the dish didn't have this problem. I suspect the ASC1 is more susceptible or the analog receiver I used before was especially good at rejecting noise.
It seems that asc was mostly design and tested with A3 unit.I use the ASC1 on an azbox ultra and an A3, both work fine here.
It's kind of harsh to blame all other brands for not working with asc !
No, as I have explained in previous emails to you, the ASC1 has absolutely no connection with the A3. The Amiko A3 was developed and released over a year after the ASC1 was brought to market. I had the opportunity to test a sample of the A3 about a month before it's release and the DiSEqC protocol was very well implemented, but I requested to FridgeFTA to add more motor positions and the ability to manually assigned DiSEqC motor positions. That is that extent of my testing with the A3. What is with your strange fascination with the A3 operating with the ASC1?It seems that asc was mostly design and tested with A3 unit.
Has any Satellite Guys member every had the problem with a DiSEqC motor starting and stopping as it moved across the arc from satellite A to satellite B? Or the Signal quality dropping and not locking while a dish was bumped East/West? These are a few of the examples of what can happen when control commands are issued out of sequence or with unique signaling methods.
Did that already. Looks good.Good to hear Ime!
Might I suggest that you do the voltage potential test as Brian suggested, before hooking it up to the dish.
