SL3S4NR2-14
dewtech, that is a SWM LNB so it should work with any of the SWM capable recvrs.
As for what recvr should you look for ?
Do you want a recvr, or a recvr that you can record with ?
Do you want HD ?
A good solid HD DVR recvr would be the HR24, and you can use that with a SWM set up or a non SWM set up.
If Non SWM and you want HD you'll need the BBC dongles added to the back of the recvr.
they're actually being sent out now as replacements for r15s and r16s that are defective instead of sending out a like receiver. they're becoming more widely used because of that.
I know that, but still, there are so few SD DVRs being used. and Directv is even upgrading customers who call with defectve DVRs to the Genie platform.....
Error code 775
