Sports bar mode is here
MitchDeerfield
934
561
Florida
Definitely use live channels only, if you accidentally use a dvr recording, the sportsbar app appears to cause the recording to be corrupted and unusable.
THE5RIVERS
SatelliteGuys Guru
Sep 8, 2009
140
46
California
Everything looking good over here!
THE5RIVERS
SatelliteGuys Guru
Sep 8, 2009
140
46
California
It's still not showing up for me...
Do you have the newest software update? Its U307. When you start up your H3, press the home button twice, then go to settings, then diagnostics and look for the software version of your H3. If its not showing u307, you wont have the sports bar feature. Make sure all of your receivers are off at the same time and that should prompt an upgrade, although I do not know what time it will show up (mine showed up at 407am). Hope it helps.
CubsWin
1,028
244
Bourbonnais, IL
Sports Bar mode seems to be working well on my Hopper 3. I really wish it was possible to use this feature on the 4K Joey, but at this point I would just settle for working PIP.
avediswolf
I'm Back!
453
15
Columbus, Ohio
I've had every issue mentioned, Blank screens, Dropping audio, even a full on H3 freeze up,
After about 4 separate reboots, it started working like it should.
