HR54/500 Internet Reconnect Issue
gobearsnfl
12
Arizona
I have had this Genie for several months and my internet connection has never been consistent. I have been using wireless connection have switched it to a wired connection. Periodically I press Menu button and my menu says Reconnect. The only way I can get it to reconnect is to restart the receiver.
Anyone have any ideas? I think there may be an issue with my using the DirecTV app. I don't know if it's related but when I use my app and can't see all of my Playlist, I check the Genie and the Internet is disconnected.
The best way to end that problem is use a DIRECTV Broadband DECA Ethernet to Coax Adapter. Some reason if you switch to this you will never have anymore of those issues.
OP says he's switched to a wired connection....
does not mean its using a BB deca. there is an Ethernet port on the back of HR54's as well.
@ OP, if you havent already, get the Broadband Deca connected and it should solve your issue. before you connect it to your system though, go to menu > settings > internet connection > advanced > reset connection, then a Red button reset, and when you have live TV back up, go ahead and connect the Broadband deca. you probably *dont* need to do the reset, but it cant hurt.
DTV in Canada
King Quest auto satelitte dish with a Direct TV H24 receiver
