and to answer the node on Hopper 3 question, change node to hub and there you go...
No, they don't do exactly the same thing. The node allows 3 channels, the hub allows 16 and is hybrid. They are very different.Leave it to Dish to change the name to make things sound more complicated. They both do the same basic thing; just two different generations of equipment.
Thank you!![]()
I'm with Bobby, also. Node = DPP, Hub = DPH. Using a Node with a Hybrid LNBF is a mismatch and the H3 requires DPH/Hybrid.Maybe HipKat can chime in
And what I'm saying is that the electronics in the hub and the node are entirely different. Both the LNB and the hub are integral pieces in the setup. As HipKat just told you, if you mismatch a hybrid LNB with a node, or vice versa, it ain't gonna work.What I'm saying is that the hub isn't what slows the 16 tuners. If the hub did that there wouldn't be a need for the new lnbf or the dph42 switch. If you lay everything out in a diagram the hub and the node go in the same place in the system. Lnb-> node/hub -> splitter/tap -> hopper/joey(s).
https://rvseniormoments.files.wordpress.com/2016/01/h3_dph_info.pdf
The Node band stacks 2 lines from a DPP LNB to provide 3 tuners to a Hopper 1 or 2.
The Hub is more like a tap and just provides a way to break out the MoCA from the satellite signal from the Hybrid LNB or Hybrid switch. You don't even need a Hub if you're using just a Hopper and no Joeys or other Hoppers.
The Hub is more like a tap and just provides a way to break out the MoCA from the satellite signal using a Hybrid LNB or Hybrid switch. You don't even need a Hub if you're using just a Hopper and no Joeys or other Hoppers.
Yessir, didn't read this before my last reply but from the start I figured the hub was a glorified tap
