Internet issues
Kaygirl
46
4
South
Anyone else having this problem? Suddenly, we can't connect our receivers to the internet because if we do, the TVs connected to Genie minis go blank. So I have to disconnect the Genie dvr and the other TVs come back on. I've talked to Direct and they r working on it, they say. But it's been about a month!
Surely I'm not the only one having this trouble.
Mine is the same receiver, it connects, but says my speed is too slow and can't do anything, even though I have speeds over 20mbps
Have you Restarted the Hr54 Either by Pressing the red button on the side of the HR54 or using the remote press Menu -Settings -Reset - -Select Restart the receiver (ONLY) Follow the Screen instruction press (-) to accept - When your tv Picture returns - Then try to connect one of mini's -If it connects then do the other one.
NOTE: - Only select RESTART the receiver Selecting anything else will wipe out all your recordings and setting - and return to like is was day one of your install.
Many, many times. The internet problem started after one of their updates and Direct acted like it affected a lot of people and that they're trying to fix it. I thought someone here might have the same problem. Guess not. ??
Hi Kaygirl, I also am having issues with the internet and my receiver, but my issue is with my HR44-500. When I first got setup it worked fine for several days; long enough to get the On Demand and other features activated. Then I got a FW update to 0x0D80 and it has been garbage ever since. If I completely wipe and reset my internet settings, along with a reboot it will work again for a few hours at most, and then it will disconnect with the "Reconnect" error in the menu. A normal reconnect process does not work at all; I have to go into advanced IP settings and manually set my IP and then reload the box.
It's frustrating as hell; I just switched to DTV from Dish and it has been a lot of pain. I've tried talking to reps and they just have me go through the reset process every time; they have never mentioned any known issues with an update. Sorry you're suffering from it too, but OTOH I'm glad to hear that I'm maybe not alone. :)
Misery loves company?
Have you tried setting the IP address manual making it static?
Also -after you do that -since your new load is 0X0D80 -from the menu do a search "TYPE" CLEARMYBOX -the press search all -your box will reset -Making the ip address static will disable DCHP upon boot and it's one thing less the box will have to do upon a start up.
I have made the IP static; as usual it helped for a little while but then stopped working again after a day. I'll try the box reset and see if that helps too.
Doing the clearmybox- Flushes all the guide data and Vod information -so that will take 24 to 48 hrs to completely rebuild - Another thing to try have you Check your router for Any Software upgrades? sometimes resetting your router (restarting it) might also help
It's not my router; I have a Nighthawk AC1900 running DD-WRT and I have done everything I can on it to resolve this, including plugging the HR44 in via Ethernet and disabling the SPI firewall. I've even tried connecting it directly to my Nighthawk M1 (which I use for my home broadband) to no avail.
I did change out my router after I had my DTV service installed, so maybe clearing the settings will help. It's certainly worth a try. Thanks for the advice; I'll report my findings back when I'm done.
EDIT: Before anyone asks yes, I did also try going back to my old router (an Apple Airport Extreme) to see if that resolved the issue, and it reverted back to not having a connection after a few hours so it's not that either.
Well, I tried vazhog's recommendation, and it worked: receiver connected to the internet right away and started updating. Now, about four hours later, it's not connected to the internet anymore and I'm getting the Reconnect error. What a frustration.
Yes, I got mine all reconnected and working again and it lasted for almost a week until it suddenly froze n the middle of a show. Yep, it had turned the clients off until I disconnected from the net again. I'm tired of direct telling me it is working on a fix.
Kaygirl posted that she is using clients, what about you ZombiePete? If you are both using clients, maybe going to receivers or dvrs will fix it. I have an HR44 and HR24 and never have this issue.
Winegard ORIGINAL Carryout & R22-100
25$ promo
