Netflix Hopper 3 Question
Ok I checked my speed for the WIRED internet to the hopper and it comes in at 74mpbs. I checked the Netflix network twice and it comes in at 0 connection speed and red Xs on server 1,2,3. It says your device may not be connected to the internet . I then went back to the Netflix app after reloading it and the shows play just fine. So I don't know what that means.
Did you do a Netflix Internet test after you did a reload? The red Xs probably would be green and connected to the Internet. I seen that too a couple of times and performing a pull the chord reboot fixed everything and the test showed all green and connected to the Internet. When you do a Netflix reload do you have to enter your email and password again or did it stay for you?
Wonder how the Hopper is 12 and Hopper Netflix is faster at 18! Haven't seen that before.
I'm still wondering why my LAN is over 900 and and my WiFi is only 90 and then why the Hopper is only 12, yet I've seen On Demand d/l at over 50 on it before
I had the same issue till I installed a Cisco Wireless Mini USB Dual Band adapter. Since I switched to N band 5 GHz my WiFi speed shot up to just about what I get with Ethernet cable. So take a look at your computer WiFi network setup. Might be why you get such a slow WiFi speed. Of course this all depends of your router capabilities.
Just reported the Hopper Netflix app Internet speed is too slow to MattG. I did a check this morning and my Hopper Ultra HD 4K list is not there. Performed a remote control Hopper reboot and it now appears. Netflix app speed is 18 Mbps.
Yes , I checked it once before and after I reloaded it and still no connection. But the shows all play just fine , so I don't know what that means. I didn't have to re enter my user I-d or password. I'll try a power cord reboot and see if it changes.
Definitely use a dual band router for 5G wifi. The 2.4G band is so crowded nowadays that it can significantly reduce your wifi speeds
It sounds like you need to update or replace your router. I have a Netgear R8000 that has dual band 5 GHz and 2.4 GHz. Although the 2.4 GHz reaches farther the maximum speed is 30-50 Mbps versus 110-120 Mbps for the 5 GHz band. I have Gigabit switches throughout the house so most of my 40 devices are wired. My iPhone, laptops, IPad, Amazon Fire TV, and Roku 4 are WiFi since they are portable. The router auto balances my load. I also use fixed I/P addresses for my devices.
Good info, my phone is connected to the 2G and my Hopper and TV to the 5G
Mine is dual band, but it's getting old. The way I was taught was connect devices to 2G like phones, laptops, etc and use 5G for devices that primarily stream
Connect all devices to 5 Ghz unless they aren't capable or are too far away.
Interference on the 2.4 Ghz band is enough to choke throughput to a screeching halt.
I have all devices on 5 Ghz except my security camera which isn't dual band. Also if I'm outside working, my phone goes on 2.4 because I need the range.
Haven't heard anything back yet from MattG. He must be on his days off. I was reading some more about the Internet with Netflix and discovered that the Netflix Internet test is in the Netflix settings menu. Sure a lot easier than doing the marching sequence commands with the remote control. :)
I have two Hopper3 receivers. The Living Room Hopper3 is wired to my Gigabit Switch. The Family Room Hopper3 receives the internet connection by the coax Moca. I had it also connected but the Hopper3 would always ignore the wired connection on the Family Room Hopper3. Both Hopper3 receivers show a download speed of 112-117 Mbps. The Netflix app on the Living Room Hopper3 shows the correct home address of 192.168.1.19. It also shows connection to Netflix Servers 1,2, and 3 and shows a download speed of 16-18 Mbps.
The Family Room Hopper3 which is connected by Moca shows the correct home address of 192.168.1.21. However the Netflix app on the Family Room Hopper3 has an incorrect home address of 169.254.129.96. It also shows red X's for Netflix server 1,2,3 and no connection speed. Yet Netflix works on this Hopper3 but no ultra HD.
I am a special minority since I have 2 Hopper3 receivers. I am not concerned since I use my Sony 4K or Roku 4 to Access Netflix.
It's recommended to connect both Hopper 3's to the internet but to different Networks rather than one shared connection with only 1 Hopper 3 connected or connecting both Hopper 3's to the same network - which is a big no-no
Reactions: pattykay
Unlock movies already recorded on dvr
Remote Help
