Agreed. If there's an electrical problem in your house, it's much better to be told that by an electrician, instead of a Fire Department investigator.
absolutely - and I'm looking for some one now. Thanks!If adding a UPS solved your Hopper issues, you almost certainly have some problem on that electrical circuit. So unless you are absolutely confident of the quality and condition of the wiring throughout your house, I would call a good diagnostic electrician today. It could save your life.
Can't wait to hear how goes it.absolutely - and I'm looking for some one now. Thanks!
Congrats on finding out the problem and yes I would have your circuits checked by a pro, you never know it might be as simple as replacing a breaker but better to be safe than sorry. Everybody likes a happy ending.Thanks all - Since it's been almost 2 full days now, I think I can safely say that I've found the problem (with much help) - the Hopper seems to be working flawlessly (or as close to "flawlessly" as a Hopper 3 can get). I'll pursue the electrical issue(s). I wouldn't be surprised a bit if I don't find some imbalancing here too.
Thanks again.
Thanks - Being able to watch TV again calls for a PARTYCongrats on finding out the problem and yes I would have your circuits checked by a pro, you never know it might be as simple as replacing a breaker but better to be safe than sorry. Every likes a happy ending.![]()
- just no "roasts"!Me too - I'm not sure I can afford this, but on the other hand, it sounds like something I can't afford to leave to chance.Can't wait to hear how goes it.
When houses are wired, many homes have outlets daisy-chained with romex, where the wire ends are stripped and plugged into holes on the back with spring-loaded contacts. This is very common when electricians are rushed or low-balled for the cost of a job. It's not unheard of for half a dozen or more outlets to be daisy-chained in this manner. The wires can tarnish, those spring loaded contacts have been known to weaken, or heat up, and become intermittent. Or even cause electrical fires in the walls in extreme cases. Competent electricians that are not rushed will strip the wires, bend hooks on the ends, and fasten the wires to the outlet with the side screws. Much better contact and much less chance of issues in the future. Prior to becoming a broadcast engineer, I was an electricians assistant. I pulled all of the wiring and mounted the breaker panels and outlet/switch boxes, preparing the site for the electrician to come in and make the connections. I observed many electricians at work. As a broadcast engineer, I had to wire studios and broadcast stations at times.Me too - I'm not sure I can afford this, but on the other hand, it sounds like something I can't afford to leave to chance.
Thanks for the excellent summary of potential wiring issues. But even if the wiring is good to go, your other point about what else is on the same circuit as the Dish/AV equipment, is something for everyone to think about....You don't want your sensitive electronics on the same circuit as a heavy startup demand appliance, like a fridge, freezer, air conditioner, electric fireplace/heater, or dehumidifier. Good luck!
When I would buy a house, I would go through every outlet and switch box, replacing outlets and switches with higher quality, and redo all of the connections from plug-in on the back to secured under the screws.
You may want an electrician check your wall switches and outlets to look for these less secure way of wires being attached. Load balancing is important as well. You don't want your sensitive electronics on the same circuit as a heavy startup demand appliance, like a fridge, freezer, air conditioner, electric fireplace/heater, or dehumidifier. Good luck!
Nice pun! (current, as in electrical current)Anyway, I don't know what (or if) this has anything to do with my current situation...
Measured in amperes!Nice pun! (current, as in electrical current)![]()
WOW, I am so sorry. This sucks. Maybe your Hopper has bit the dust.I'm not sure if I'm more embarrassed or frustrated: My Hopper has started flaking out again. It went almost 3 full days without a single glitch, but I got home this afternoon, and I have a dozen or more programs that are "segmented" - multiple pieces. I don't know where to go with this.
I don't think i'll convince Dish of that - they've had 2 techs out, replaced everything INCLUDING the H3 (this is the 3rd one now for essentially the same issue)...... DANG!! I'm really at a lossWOW, I am so sorry. This sucks. Maybe your Hopper has bit the dust.
I would go the route of having an electrician check the house out before I make another call to Dish. Possibly any electrical problems are affecting/damaging the Hoppers which is why they work for awhile, then flake out - albeit I know this is one you had problems with previously before changing outletsI don't think i'll convince Dish of that - they've had 2 techs out, replaced everything INCLUDING the H3 (this is the 3rd one now for essentially the same issue)...... DANG!! I'm really at a loss
Absolutely - I can't see that this is any longer a Dish problem. Something weird is going on here. Hopefully I can find someone affordable to check this out.I would go the route of having an electrician check the house out before I make another call to Dish. Possibly any electrical problems are affecting/damaging the Hoppers which is why they work for awhile, then flake out - albeit I know this is one you had problems with previously before changing outlets
