I'll go up tomorrow and cap the 129 horn on the main LNB and see what happens.The system will use the best signal it can find but it can't find or access the signal from the wing dish in this configuration. The wing dish needs to be connected to the switch.
Sent from my SM-T280 using the SatelliteGuys app!
Also does anyone know what the nominal level off 129 when set up for normal use? Once I block it when I run tests what should I expect? And what transponders should I do the check from?
