New Guide UI now rolling out (plus HDR support!)
One thing I've noticed recently, i think its mentioned above, is like, when I'm recording an Astros game, i'll Get home, go to the playlist/DVR, and its not listed, but when i go to the channel, it is recording, and I can rewind to the beginning. Then later it shows up in the playlist, just for some reason, at the beginning of the recording it doesn't show up on the DVR.
Also, right now on the Frmware site, for the HR54-700, It doesn't show a version at all, its blank..
a couple of people have posted the plylist issue
I'm on 113d now, running fine except for the one day it slowed to a crawl, reboot and been fine since ...
110C like i said is announced, but thats lower than what I have, so I'll pass.
Good thing you passed ...
As I noticed 110C began spooling out early this morning apparently as a new rolling NR for the Genies (not the lites).
So I d/l'ed it, and yes the dumb black bar is still on this one ...
Sign ...
Sent from my LG-H932 using Tapatalk
Sign ...
Well, now you Seriously want a CE this weekend.
You may be in luck ...
Reactions: HoTat2
That blue line needs to go, right now I will settle for stability and they are doing some testing right now. Looks like E is on the way maybe soon?
Reactions: whitewolf8214
For anyone interested ...
110C is in the datastream at the moment for the HR Genies (not the 34)
110D is in the stream for the HS17
Load at your own risk.
Interesting ...
Current NR (not rolling) appears to have changed from "1104" to "1110," so gave it a d/l.
Don't know what it corrected or improved, but it wasn't the stupid back bar.
So still no joy here ...
The next push was expected to be 113F Monday tonight. Engineering is delaying that until probably Tuesday night. The build number would be 113F or higher. It is expected to be primarily stability based on feedback of 113E. Will provide more information when we have it.
There will be both a push and regular CE tonight (Tue) for version 113F. If you submitted to be on the push list, you should get this pushed. If you are not on the push list, you can pull it between 8 and 11 PM PST (11 pm to 2 am EST). The National Release build will be placed back in the stream after 11 pm PST.
Interesting ...
I saw that in the stream as well, but its still lower than what I currently have so I passed.
Best Number for Returning Customer
directv satelite change?
