I've got a faulty AirTV module. It wouldn't connect to the channel even though it was showing a strong signal. I went back to the Dish module that I had replaced with the AirTV and that problem went away. Just today I was going to contact AirTV about getting a replacement, it had worked great for about 3 months, but you can only call in, no email address available. I didn't have time to hang around on the phone. I'll do that on Monday. Not sure what their reaction will be to using it with a H3, I'll let you guys know. Depending on the module you are using . . . I know that tuner sensitivity varies greatly. I spent a lot of time and effort to get my signal strength up to tell Dish what they could do with their local channels. Some tuners the signal was fine, other not so. VIZIO tuners suck. I was finally able to get adequate signal to all tuners in a difficult terrestrial situation. Attached is a picture of what it took. I had to split the VHF and UHF because the
the mountains somehow changed the path of the UHF signal (Sock Fairy) so to get both with one antenna you compromised both signals. You can't tell in the picture but there is a 1 to 2 degree difference. VHF is pointed directly at the transmitters, UHF is offset.
UHF
UHF
