Missing with CBand
calmeidajr
155
5
NJ
hello all I'm about to put up my motorized ku system. I want to get a c band system but am I really missing out on a lot of content without having one? Will KU suffice my programming needs? I'm into wild feeds and sports backhauls. Thanks for your input.
If all you care about are wild feeds and sports backhauls, Ku should do you just fine. I recommend a 1.2m dish to pull in most everything you can get on Ku.
Reactions: calmeidajr
Yep. Lots of sports feeds only on C. You miss a lot without one. Turner, CBS, Fox, and ABC use C almost exclusively for all their backhauls. ESPN uses a mix of both. NBC usually uses Ku. UFC, Showtime, WWE and other fight PPVs usually show up on both with an identical feed on each band for every event. Most news remotes use Ku.
Awards shows and concerts are a mixed bag. I'd say like half are uplinked on C and the other half on Ku.
MY KU LNB and diseqc switch getting burned.
FatAir
