Hopper 3 channel guide
I just upgraded to the Hopper 3 and cannot figure out how to get the channel guide to only show my HD channels. Is there any way to do this?
Press Home twice, go over to Guide and select, press Options, go to Guide Settings and select it, go down to Hide Duplicate SD Channels and enable to On. This will hide the SD channels that also have an HD version. You will see SD channels that do not have an HD version.
So there is no way to hide SD channels completely like I did with my 722K?
It's in the favorites list on the VIP receivers... options of All Channels,All Sub,All HD and then 4 different list you create
Yes, the VIP receivers had an option to exclude all SD channels. They left that out on the Hoppers. I think that was to allow standalone SD channels to be seen on the guide so that you wouldn't think that a channel was unavailable at all. That was probably decided upon by how many calls they got that complained that they were not able to see the TVLand channel, for instance, in their guide while they were in HD only.
I don't remember seeing it too on the 722. Why would you want to hide SD channels completely!
If you hit Guide 3 times it went to a Gold Screen that hid all SD CHannels on VIP Receivers. I had a lot of trouble calls because people who did this couldn't find the SD only channels in their guide. It was probably removed just because of that
Edit! Sorry Bobby , I hadn't seen your post
[automerge]1581636618[/automerge]
Because I don't watch SD channels. They look like crap.
Then create a custom channel guide with no SD Channels
Or turn on 'Parental Controls' and remove all of the cruft that you don't want to see in the guide.
The advantage of this over a favorites list is that free previews will show up in your guide as soon as they are alive, and disappear when they are gone. Just don't forget your PIN.
Reactions: fmj77 and HipKat
Thanks. Will give that a shot. Dish really should add the My HD channels option to the Hopper channel guide though. Ridiculous that the VIP receivers have it and the Hopper doesn't.
...Dish really should add the My HD channels option to the Hopper channel guide though. Ridiculous that the VIP receivers have it and the Hopper doesn't.
Okay, if we are dreaming then... How about they add a seek timer that actually works, like the one on the VIPs did?
Reactions: HipKat
Very easy on the 722 K
I'd say I'm not the only one.
But one of the few... ;) On another note, I noted on my neighbor's 211K that when he is in HD channels only he is unable to see the music channels in the guide. You can input the channel directly and it goes to that music channel but it doesn't appear in the guide. So, because he uses the music channels often he must stay in All Channels.
I've lost closed captioning on TCM. Am I alone?
Free Dish OTA tuner
