Dish Hopper Slow
Sea Beagle
On Vacation
200
109
Example. I DVR that takes like 3 minutes to show up. Then after that shows up o choose a show by scrolling through the recordings. That takes a long time for the curser to move across the screen. Then when I am able to choose the show I want that don't show to.
Then the Hopper reboots itself. I see in the see this on the screen.
After the reboot the Hopper is fine.
Any one ever have this happen?
How can this be fixed?
Sent from my iPad using Tapatalk
Was it brand new or refurbished when you got it? Mine was new when Dish installer came to my house to replace the older model Hopper about 3 years ago. I have never seen that code before.
Reactions: Howard Simmons
Hello, Sea Beagle. The 1599 message on its own is normal and usually occurs during the regular nightly update. If this is happening consistently outside of that time, it could point to an issue with the Hopper's hard drive. We always double-check that the Hopper isn't overheating by having enough air space and is on a hard service.
There is a partial reset that can be done to help with this consistent system check. You should only need to do this once. To process a partial reset:
1. Press the MENU button twice or the Home button three times
2. Select "Tools"
3. Select "RESET TO FACTORY DEFAULTS"
4. Select "PARTIAL RESET"
5. Select "Reset" on the Reset Warning pop-up
This will not affect your timers or any DVR content. If you try this reset and the issue continues, please chat with us online at https://my.dish.com/support/contact. Our chat support team is available every day between 8am-midnight ET to help.
I've always thought something was wrong with my 3rd H3. The one I bought. The other one that we lease, haven't seen this. I get this error and the pop up that says it's checking the hard drive. Always comes up OK.
I'm jumping on the Partial Reset. Wish I had known about it long ago. I wonder if it'll fix the "Nightly Reboot" that happens at all hours of the day, will hound the heck out of ya and/or will just do it whether or not you want it to or if a recording is happening.
Thanks!!
AND there's Resets for YouTube, Prime and Netflix. "Christmas!!!"
Doin' the Partial this very second . . .
I read in the description on the hopper there was nothing about the favourite lists being deleted or I wouldn't have did the partial reset.
Reactions: SandFarmer
Too True! A little too short on the explanations most of the time. I needed a fix so even if I knew, I would have done it.
Now I have channels acting like I have dish interference or when you skipped back less than a minute and the machine gets all wonky. That started this morning.
DISH Anywhere and data usage
Hopper 3 Extremely Hot
