Not a good sign. Do you have trick play on the Hopper itself?Joey won't jump forward or backwards when playing recordings. Flashes "live TV" instead.
Don't know what trick play is.Not a good sign. Do you have trick play on the Hopper itself?
Sorry; it's anything not involving linear playback. You mentioned "jumping forward or backward", which are two forms of trick play. I would also include pause and slow motion. Note that you cannot skip forward on live TV, since that is a future part of the program not down from the satellite yet. But jumping backwards should still work, unless your Hopper internal disk is deceased.Don't know what trick play is.
Trick play is what we use to refer to pause/play/ff/rw/etc. functions. That is what TheKrell meant.Don't know what trick play is.
Hard RebootI was experiencing the same thing. Unplugging the power to the Joey and plugging it back in fixed it...for a couple of days. I now have the Joey plugged into a timer that removes power from it every day at 4 a.m. for a couple of minutes, then powers it back on. Problem has disappeared. BTW, I do the same thing with the Hopper. That has also solved all issues I was having with that device.
f**k you. That's the last time I try to help someone here. I'm surprised anyone asks questions or seeks help, with responses like that. f**k you.
Wow Fred, where is your sense of humor?f**k you. That's the last time I try to help someone here. I'm surprised anyone asks questions or seeks help, with responses like that. f**k you.
Sorry, I don't find it funny when someone basically says to me, "You're a moron if you think what you're suggesting is a good idea." My suggestion is a valid idea that works, and I don't need some a$$hole sh*tting all over it.Wow Fred, where is your sense of humor?
Good grief Fred! The cartoon was meant in jest and merely shows another way to do the same thing as you reported doing. No need for vulgarity.Sorry, I don't find it funny when someone basically says to me, "You're a moron if you think what you're suggesting is a good idea." My suggestion is a valid idea that works, and I don't need some a$$hole sh*tting all over it.
I apologize. I completely misunderstood the intent of your post. It's all good.Sorry, Fred, that was not my intent. You came up with an easy answer and solved your problem faster than the software engineers at Echostar ever will. That's why I linked that cartoon.
To be fair, I have sent this same cartoon to some of my coworkers when they have memory leaks that they hadn't managed to track down.I apologize. I completely misunderstood the intent of your post. It's all good.
I use:Fred; I apologize, too..I never meant to hurt your feeling when I responded to Foxbat. It is quite the opposite. I thought Foxbat's response was funny. We leave funny drawings, cartoons, gifs here to make it less stressful.
Foxbat has been here for a while. You just misunderstood. Things happen.
I have a question for you. The timers I own from past are sort of too bulky to fit on a surge protector. What brand do you use? Any recommendation?
