C Band and a 120cm dish... pointless?
nwkn1g
3
Vegas
I was given a terrible ground mount 120cm dish. I paired it with a Titanium C140 lnb and have only been successful locking onto 105w 3881H. I scan in and can watch the CH-1, CH-2 and CH-3 channels but no matter what, nothing else locks.
Where the dish is currently sitting I can only see a small portion of the arc. I'm wondering if there are any other birds out there that might be possible before I try moving it somewhere else. Or is it a lost cause and I should just put a KU lnb on it? I'm located in Southern Nevada if that matters. Thanks
I've received watchable channels using a 1-metre and a 1.2-metre dish on C-band from 139W, 117W, 115W, 105W, 101W, 97W and 91W in recent months. Many of the channels received were from Mexico therefore in Spanish. Blind scan those satellites and you may be lucky to receive some.
Nothing under 8 feet is worth bothering with for C-band. Those times are passed now, as most need far more s/n ratio to be lockable.
If you already have the small dish mounted, why not just try rather than listen to others who may never have tried a small dish?
Here were my results from January this year while using a 1.2m offset dish on C-band across the arc from 139W through 84W. Since the weather is now nice, I plan to check this again in the coming days if I can get its motor working.
I think you could get NHK World HD @ 58W with that dish if you put a PLL LNB on it and get it peaked well. It is one of the easiest C-band feeds to receive and actually might be the single best 24/7 channel on C-band FTA too! Lots of interesting new content aired there every day, and their web streams are sh*t, so you are getting the best experience via satellite. It's basically unwatchable outside of satellite because their Internet streams are so horrendously overcompressed.
Not a bad idea to have a stationary 1.2m deployed just to receive that channel. I've got it fine on a 1.2m before because it has the highest amount of error correction you can have on a feed; a FEC value of 1/2.
From their direct reception page (Ways to Watch - TV | NHK WORLD-JAPAN Live & Programs):
South & North America Region
Satellite: IS-21
Frequency: 4166MHz, Symbol Rate: 19.91Msps, FEC Value: 1/2, Polarization: H, Modulation: DVB-S2/QPSK
HD(1080/60i) <MPEG-4 AVC/H.264>, Channel Information: [1080/60i English]
Aligning motorized dish without Zenith sat
