Streaming from receivers to PC
comfortably_numb
24,633
42,326
New Mexico
I've noticed that streaming from a receiver like the Edision or the GTMedia V9 to my computer produces a stream with a lower bitrate than the originating feed. For example, streaming ABC 4:2:2 from 97 or 99 C-band from the Edision looks grainy on the PC. I've tried VLC, PotPlayer, SMPlayer and others and the result is the same. How do I stream the original, high quality TS file from the receiver without transcoding?
PS- my network is gig all around, so I don't think that's the issue.
Somehow it must be transcoding to do this streaming. IF you have no controls buried somewhere to adjust the transcoding streams, you likely can't fix it.
It's interesting that when you record a TS stream to a flash drive from the receiver(s), the result is uncompressed.
Reactions: primestar31
have you looked at the stream specs vs. recorded .ts specs in VLC? Just wondering how you're comparing bit rates, not questioning your eyes on graniness.
I'm not sure how to compare, as it isn't possible to stream directly to TSReader.
You can view stream specs from VLC. I would guess the same is true if you are playing back a recorded .ts from VLC
BIG Powerball Up Coming Weekend, Satellite Feed
Soon to be 93 W* bird if approved by the FCC
