OK, that makes sense. I will go and check that out.
I went down and checked and it is defiantly "neco" in slower case case letters.
Jim here is restore instructions provided by el bandido from Legit fta forum.
Go to:
TNAP Images - Satellite Receiver Firmware Downloads
(You want:"sf8008-20251129 usb")
Scroll down the page a bit. Find the file named "sf8008-20251129 usb", and download it.
Extract the zipped file on your computer. Wait patiently for this process to complete 100 percent as it may take some minutes.
Copy the 4 extracted files named "apploader.bin", "bootargs.bin", "fastboot.bin", "usb_update.bin" Directly to a "Known-to-be-Good" usb drive. Make surfe the copying process completes as this may take some minutes. Insert this usb drive into the receiver.
To Install:
Position the Rocker switch to Off On back of receiver.
Press and hold front power button in the middle of the receiver, and position the rocker swicth On while holding
the power button in the middle of the receiver. (Front Button will turn Red). Release the button after about 5-10 seconds.(UPdt should show on display)
Wait 2 minutes. NECO should be displayed on the front of receiver.
Using the receiver's remote, Hold directly in front of the receiver, and Press the down arrow button one time. (Down arrow button is directly under the OK button on the remote)
Press OK button on the remote (1)
Press OK button on the remote (2)
Front display should start counting...DO Not Power OFF!!
When the receiver finishes installing and rebooting, you should be in 720p 60Hz video format.
