amerhi,
You're getting good advice, but let me offer a few suggestions.
1st, when I go "bird hunting", I've found it easier if I
"load the gun first".  What I mean is, manualy enter some transponders
before starting, this way the strength & quality meters work.
You've probably already moved things, but if not, adjust the LNB's skew
for best signal before you continue. Also check focal point (slide it
back and forth towards the dish) for best signal.
What follows is for a Coolsat because I'm familiar with them.
(I'm assuming you blind scanned 127W with it)
Select Galaxy 10R and then go to setup. Drop down to Manual Scan
and the transponder should be 11.720H if you're still pointed at 127W.
In the upper right hand corner, it should say: PiTV. (if you did a scan)
Down arrow to Transponder Frequency and right arrow to see if you've
got any more transponders.  If you don't have 12.104, add it by pushing
the green button.  It should be FREQUENCY 12.104, SYMBOL RATE 2.222 snd
POLARIZATION V
This transponder is about the same strength as the one you found on 127W.
Now, I like the Motor Settings menu for tweaking, because it lets me
change transponders and also see and hear the Quality.
If you're still on 127W and tp 11.720, you should be able to see any
changes you make. Again, it should say PiTV at the top of your screen.
The dish has to be elevated for G10R, so raise it as much as you can
without losing signal completely.  Now, select tp frequency 12.104 and
nudge the dish a little bit to the East. Hopefully you will have enough
elevation to find 123W.  If you get a decent signal, the upper corner
will show: WEGENER
