2 Dishes to 4 receivers?
rcs4787
9
* 1st Dish 1 SAT, 1 LNB dual output
* 2nd Dish 2 SATs, 2 LNB quad output
Thanks for any info, will read just point me in the right direction, no spoon feeding here.
Also using Viewsat Ultra if that helps
I would use 3 @ 4x4 Multi-Switches (or one could be a 3x4 multi-switch for the dual lnbf) and use a multi-switch for each lnbf and then run cable to 4 @ 4x1 diseqc switches (one for each receiver), and from each multi-switch into a different port on the diseqc switch. This would work fine....
Al
