This is my first post.  I could really use some 'forum' help.
One year ago, I traded my DirecTV satellite for a GEOSAT AMC-4 system from AdventistSat.com. Components: GEOSAT pro DVR1000ci receiver, 36-inch GEOSAT pro dish {with Azure Shine stamp} and one std FTA LNBF-mini.
I essentially get 3 channels: 3ABN, Hope and LLBN. 'Quality' on 3ABN is 98 {about 75 on LLBN}.
I discovered glorystar.tv when attempting to re-visit adventistsat.com. There I discovered 'a bunch more' free channels {aka: Galaxy 25}.
On Glorystar's website, I see two options:
Option # 1 - consists of an upgrade kit for $48.00. Glorystar appears reluctant to offer this option. They seem to be saying: "Good Luck Pilgrim - you'll need it to re-program your receiver. We do NOT provide ANY configuration information. You're one your own."
Option #2 - consists of the upgrade kit PLUS an already programmed receiver for $154.00. If I were to opt for this option, I would call glorystar and ask if they'd substitute a 'programmed' DVR1000ci receiver {another $124-150}.
My questions:
1) Is it easy/doable to use my existing DVR {with AdventistSat.com's AMC-4 programming} - and 'add' the Galaxy 25 channels myself? If so, what's the best way to do this? {another words: anybody got instructions?}.
2) Or, does 'conventional wisdom' suggest I purchase an already programmed unit as part of the upgrade? {which contains all the necessary instructions and information}.
3) I'm thinking: when I attempt to reach two satellites via one dish and two LNBFs, there will be some 'compromise' - and ALL 'Quality' levels will take a hit {especially LLBN on AMC-4}? But, if enough 'tweakin' is done, maybe they will all come in ok {enough}.
4) I downloaded the installation guide for the DVR. Page one contains a box with places for Dish Elevation, Compass Azimuth AND Skew Angle. I've no idea how to compute 'Skew Angle.'
5) I visited GeoSatFinder and came up with two sets of settings:
AMC-4 Compass: 136.6; Elevation: 45.6; LNBF Rotation: -24.4
Glorystar Compass: 133.7; Elevation: 44.7; LNBF Rotation: -26.7
No hint of Skew Angle. I'm currently set for AMC {above}. Either {logically}, one would seek to split the differences, OR: the 4 degree clamp compenates {??}. Do I start from the AMC setting? Or, do I begin with some initial aiming of the dish {before looking for a Quality signal on AMC?
My ZIP code is 93060 {Santa Paula, CA}. Based on the above information, how do I come up with some initial settings as defined in #4 above?
As you can see - I really do need help.
Thanks - James
My questions:
Thanks - James
