Sometimes when troubleshooting a setup the functioning of a switch comes into question. If you have a known working spare you just swap and test again. Now you have the doubtful one in hand and can test it thoroughly.
What I had in mind is a receiver set up with some satellites programmed in but not actually connected to any dishes/lnbs. A short coax from receiver to switch will be sending the required signals to the switch depending on which sat is selected. Can we now use a multimeter to reliably detect how well the switch is doing its job at each of the outputs?
Is the receiver necessary, is there a different way of doing this test more simply?
