Hi!
E* came yesterday and replaced the LNBFs/brackets on my SuperDish 121 with a new 118.7 re-point kit and everything looks good.
A few questions about Signal strength. When I go to check switch and cycle thru' my satellites, the signal strength (I live in Dallas, TX) is in the high 60s on 110/119 and a lowly 49-52 on 118.7 I also see a yellow msg. that says 'new software download may reflect a lower signal number than before, even though signal strength is as before'. Are my signal #s fine after the re-point kit? I also ask this, because they initially had a tough time getting 118.7 and eventually called somebody to re-check EL/AZ readings for my zip.
Also, as I cycle thru' the sats, I still get a green bar in the 50-60 range for 121 (previously pointed) and 148 (even though none of my LNBFs were pointing there ever). Since my 3 LNBFs point to 110, 118.7 and 119, I was surprised to see green bars with values on 121 & 148.
