13V/18V C-Band LNB Needed
PopcornNMore
3,635
128
Gibsonia, PA
Do they make a switchable 13V/18V C-Band LNB with a flange for use with an FTA receiver?
I have a 1.8m Channel Master offset antenna and would like to buy the feedhorn below to get better reception. I have a Coolsat 4000 Pro receiver.
This is my uderstanding . If it is a LNB , a polorotor is normally used in the feed horn to change polarity . The picture seems to show a flange fro a LNB .
A LNBF uses 13 / 18 VDC to change the polarity , but do not know of one that fits that flange . The LNBF's I have seen are complete units that fit a scalar ring . And slide in & out the scalar ring to adjust f/d .
Wyr
So I guess if I use this feedhorn with a regular C-band LNB I would only get one polarity.
However they sell KU band LNB's that have a C120 flange that change polarity with 13V / 18V.
I haven't seen the animal you are looking for. Have you tried Skyvision, or contacted the LNB manufacturers (Cal Amp, Norsat, Grundig) themselves?
If there is a way to get both polarities on that feed , it might be with what I have read of a stacked LNB . But , some one that knows more , what a stacked LNB is , will have to help you .
I have seen pictures of Ku LNBF's that use the C 120 flange .
Wyr
