4.2.2 PC USB Tuner?
Ranger One
3
Cheektowaga, NY
Recently purchased an OpenBox S10 which works well though I can't view live 4.2.2 feeds with it. (Unless I'm missing something!)
Is there a PC USB DVB-S2 tuner out there that I could use to view live 4.2.2 video?
I was looking at the Prof AdvanceTune 7700 USB.
Any help would be appreciated!
I would recommend an internal PCI or PCI-e DVB-S2 tuner card. A USB tuner device may give you a lot of stutter on high bitrate feeds (at least it did for me; with an internal card no probems!)
If you are looking for a good solution that directly interfaces with your TV, I suggest purchasing a AZBox which does 4:2:2 natively. I learned the hard way, that this is the easiest solution. Plus, the AZbox does just about everything you would want to, including the ability to stream to a local network. The blind scan is not as good as the Openbox, so I have mine setup as a slave. I use my USB tuner to investigate feeds using tools in Linux.
Let me know if you have any questions.
Chris
