811 menu text woes.
DirtyMack
67
I've noticed that whenever i switch over to my TV's component that outputs in hi-def, the menu text is 'doubled'. In other words i see double lines, the standard white text plus a red underlay. The picture is also slightly funky, with a slight color bleeding. These are only visible on the left and right side, more extreme on the left side though.
Is this a calibration issue? I've used the Avia HT tuner DVD, but to no avail.
The text looks fine when output through my S-video.
I have an extended warranty through Sears, maybe I should call them to check it out.
Convergence issue, Do a multi point if you can or at least a touch/magic focus.
Is that something i can do without having to access the service menu?
Thanks!
