811 Problem - High pitched buzz then no sound
Mark_AR
1,448
North Arkansas
OK, I broke it. Sorta.
I was flipping through the HD channels and heard a high pitched buzz(Like a modem connecting) then all the sound went bye-bye. Turning the volume up a little, I noticed about a 14,000hz buzz (Not like the 17,000 hz horizontal oscillator whine)
Turning the 811 off and on again had no effect.
I did a hard reset. Still no sound after coming back up. Kept fiddling with changing channels and sound came back finally.
It wasn't my TV. It was the 811. *sigh*
Anyone else have this problem?
I had the same problem once, turned it off and back on, it hasn't done that again, yet. Have lost sound a few times since, in between the lockups, that you have to unplug the unit. I am not using the toslink.
This thing is buggy, but I got to watch CSI in HD last night, so Im happy.
Mark,
The NTSC raster frequency is 15.75kHz (525 lines x 30 full frames per second) not 17kHz as you're reporting.
I've mentioned this problem to Scott privately as soon as I had my receiver and publically in a couple of the bug threads.
Cheers,
John Kotches said:
Mark,
Cheers,
Does this freq. hold true for 1080 HDTV signals also? I'm not an expert, just passing on what I find. It was on every channel that I tuned to until I got sound back working again.
Usually people can't hear the high pitch on their regular TV sets, but I can. Good hearing can be annoying at times.
I believe the horizontal oscillator frequency is 15,734Hz (525 linesX29.97 frames/sec). :) It was changed from 15,750Hz to accommodate the color subcarrier. :)
It would be about double the frequency for 1080i (1080 linesX30frames=32,400Hz)
If that is the case, then there is another source of the frequency since 32khz is about 12khz above the normal human hearing range.
I was wondering why the neighborhood dogs went nuts every time I watched a HD channel.
lamer,
Yes, but at far less than a 1% error I don't find that to be particularly relevant.
Mark,
I'm nearly 100% certain that you're getting raster sampled and passed digitally. THat's what it sounds like to my ears.
Cheers,
Newbie OTA HD/SD question.
721 KABOOOM!
