Add 3rd tv to receiver
bodinsmom
omaha, ne
I have a Dish DVR 625 connected to 2 tvs. I would like to connect a 3rd tv to the receiver (I know it will receive the same programming as one of the other tvs). How do I go about doing this? My house is wired for cable, but when I tried connecting the cable to the tv, there was no signal. So, I'm probably missing something.
Did you split the signal? Which tuner are you splitting? Sharing the signal of #2 will allow you to take the uhf remote to the tv. But you will have to use a splitter to feed your existing tv and your new tv you are adding
As long as that cable is originating from the 625 it should work the same as the other 2 TVs. Basically you are splitting the signal to 3 TVs. You may have to do a channel scan on the TV.
Hello From Northern Michigan
1000.4 Just for 61.5?
