Advice on Rotator for Winegard HD-7694P Antenna
saintbaud
3
morganville, NJ
I have installed my Winegard HD-7694P and have been getting excellent signal strength. Thanks to this forum!
Now I would like to install a rotator so I can get stations from Philadelphia in addition to NYC stations. I would appreciate some advice on a good rotator that does not break the bank (I have a "10 Foot, 1 1/4 inch" chimney mounted mast).
TV Fool
Thank you,
Baudelaire
The Channel Master 9521A should work well with a mast no longer than 5 feet above the motor.
The stations from Philly look to be a challenge from your location with a 7694. Can you re-post the report with the approximate height of the antenna?
Any name brand rotor should work. The lowest cost will give simple east west movement more expensive will add remote controls and programable locations.:)
