AMC 21 Ku gone?
  • WELCOME TO THE NEW SERVER!
sanjap
253
4
houston, tx
I have been trying for the past 3 days to lock in the PBS channels on AMC 21 but no luck. Are they gone? I get the C-band channels with no problem but cannot get anything on Ku from that bird. Are they still there? Please someone confirm.
Thanks,
Yep they still there.
I don't get any Ku TP on that bird. C band coming in strong. Using a 6ft dish with dual C/ku lnb. I used to get ku on that satellite before but recently i don;t know what happened. I get Ku on most other birds with no problem.
Sounds like it is time for a re-alignment if everything else seems to work. I had the same problem with 97W Ku back in the fall. Everything but that bird seemed to work fine so I kept thinking it can't be the alignment. I finally decided to bite the bullet and start over with a fresh alignment as if it were a new set-up. After that 97 ku came booming in. I was getting C-band side but no ku. I thought it was real weird cause everything else worked fine. But it worked after that.:rolleyes:
It is it. After re-alignment, i am getting AMC 21 now with even better quality. Seems with the cold the dish shrinks...
Glad you got it going.
If AMC21 went down it would have been a big news thing as PBS is there...the PBS feeds for all the affiliates ;)
