AMC 4 Setup - Help
slimmswitch
118
I'm located in Toronto..
I have a Pansat 2300A and a 30" dish. I'm trying to connect to AMC4 , I got a Level of 99 but I can't seem to get a quality read... Does anyone have this running , i'm trying to catch RTPi.
If anyone can help that has this running please respond ... if i could get a amc4 channel list that works for someone that would be great too.. :no
In Toronto you are looking at the below coordinates to find AMC4
Elevation=35.4 deg.
Azimuth= 210 deg.
Skew=21 deg. (don't worry about this for now)
Distance to satellite= 38180km
Aim for a channel that you know is on air like
KTEL TV
11704 Freq. /V/ 2170 symbol rate.
Or RTPI
12169 / H / 3003
http://www.lyngsat.com/amc4.html
I'm probably wrong, but if you have 99% signal level it sounds like you're either using the wrong LNB or the wrong local oscillator frequency.
What LNB are you using?
Ktel should be easy to find, I find it even when I am trying to miss it! : )
Yep! Cascades right! It sounds like its been set for a universal LNBF instead of a standard LNBF! Should work now, good luck!
Tried Again
I tried again guys .. still no luck , Guess I will try tomorrow it's getting dark...
If all else fails try a blind/smart scan and see what you get! Its a standard LNBF you have so leave that part set at 10750
More Settings From Pansat...
Here are the settings I have for AMC4 on my receiver...
LNB TYPE- STANDARD
LNB Freq - 10750
22KhZ - off
DisEqC- OFF
Skew - 0
TP - 12120v30.000
Positioner Setting - Disabled
Sat Scan - All
Does this seem to look good??
Looks good ,still getting signal but no quality? Try moving the dish 1/8th of an inch, and check for quality or do a blind scan.
Well I'll have to try again tomorrow...but this may sound dumb , but whats a blind scan?
Thanks...
smart scan? Its a scan function that some receivers have and it scans the whole satellite for live channels, it takes a lot of work out of it, your receiver will have some kind of scan function try that.
Pansat 2300A,,, I know how to scan those TP.. Was not sure if a blind scan had a trick to it.
The smart/blind scan finds lots more channels than a transponder scan! Save a lot of time too.
Just looked up on the net to see if my receiver can do a blind search... and of course it can't..
You can still get every channel a blind search receiver can get! Dont give up it will be something easy! Just keep pointing and scanning and you will get something.
I thought the 2300 had scan on it. Hmm...
KTEL would be the channel to lock onto. It is the highest signal on AMC-4. Blows all the other ones off the scale.
Freq: 11700
SR: 2.170
I just took a few screenshots off of my 2500A. But it sounds like PSB is right. You may need to adjust your pointing some more.
Check your menu for 'Smart Search'
MENU-INSTALLATION-SMART SEARCH (See search.jpg)
I included a picture of the antenna screen too. (antenna,jpg)
And the signal info for KTEL: (ktel.jpg)
Hope you get it working!
LNB TYPE- STANDARD
LNB Freq - 10750
22KhZ - off
DisEqC- OFF
Skew - 0
TP - 12120v30.000
Sat Scan - All
The TP you have above is a data cahannel. There would be no quality
Need a different TP :)
tried again with other tp and same result.. I guess i'll try on the weekend... before I toss this dish.. :mad:
AMC and Intelsat Americas 5
I still have not got my 30" setup yet... But i just wanted to know if after I got amc4 setup would I be able to catch Intelsat Americas 5 at 97.0°W with out having to move the dish?
Slimmswitch
